The carpet in my house is showing signs of age. I'd like to replace it, but all the rooms are fully furnished with big, heavy furniture, e.g. chests of drawers, king-size & queen-size beds, etc. I know I can lighten the load somewhat by removing drawers from chests, but don't know what else to do to prepare.
I can't remember the last time I had to replace carpet in a non-empty house - probably never. Do carpet installers take care of moving the furniture around or is this something I'd have to handle myself prior to installation? Can carpet be properly installed without stretching or wrinkling if heavy furniture is placed on it when it's brand new?
Time is money, want to save a ton, have an empty room for them to work in.
Once there done with that room, move it back in and they can move onto the next one.
There's no way to stretch it with heavy furniture sitting on it.
Just like any work, the more labor involved, the more it costs. Just make sure if the installer is moving the furniture that they have insurance to cover damage. In many areas, installers are not required to have any insurance of any kind.
To close this out, the guys came last week and moved all the heavy furniture outdoors through a handy double door while they installed the carpet. They were good at lifting heavy things. Not so good at reconnecting things (tv cable, Ethernet, dryer vent) behind the replaced heavy things. But it's all good now. It was worth paying for the labor. Thanks for the replies.
I'm pulling up our old carpet getting ready to put down laminate and was surprised to see that when they installed the carpet 25 yrs ago they filled all the seams - none of which are over 1/8" most are less. Is this common for carpet? Looks like they were getting it ready for vinyl :confused:
I'm just curiousRead More
We had 11 inches of rain in 90 minutes. This is the only time my basement flooded in 35 years. I've been hit especially hard by the pandemic so I have little money and it's not covered by insurance. I pulled out the pad, elevated the carpet, blew air underneath and got it dry. Basement is at 32% humidity so it dried out really good.
The carpet is a high grade commercial carpet so it;s tough to stretch. I got estimates to have it reinstalled. I just don't have the money, I was struggling financially before this after covid ruined my business. So I'm trying to fend for myself.
I was able to find a roberts 10-254 power stretcher and two professional grade knee kickers for 100 bucks, What a blessing that was. I have read and watched some youtube videos to get a general ideal on how to use it. So I know in general to hook on one end and start the stretch moving 12-18 inches across. The first room I have is 10 x 17 ft/ there are some seams into a hall and closets so I'll leave those in place and stretch pulling opposite of that which will be the 10 foot across stretch. Then I'll plan to stretch the 17 ft side to pull the toward a doorway where I had to cut a seam. I'll try to overlap it so it can be re-seamed latter on. Do you have any advice?
For the padding I'll try to slide the 8 lb [ad under the carpet against the side that I will fix to the tack strip. I've seen instructions to tape the padding and instructions to glue it down. Is there a prefered way or do you have any advice.
I would appreciate any advice you might have.
Read More
