Sewing upholstery fabric
Old 06-02-11, 07:03 AM
Micha's Avatar
Good morning!
I want to replace the two cushions on my couch with one long bench type cushion. I plan to use the fabric from the two cushions and sew them together to make one piece. My question is this: when I sew the two pieces together, should I use some kind of a reinforcement tape or strip of some kind on the center seam so it won't be apt to pull apart. I need suggestions as to the best type of reinforcement to use so it won't be bulky and any other helpful hints or tips.
Thanks.
Micha
Old 06-02-11, 07:52 AM
Shadeladie's Avatar
Super Moderator
Received 141 Votes on 110 Posts
Just sew it two or three times and use a polyester thread, which is stronger.
The only problem I see is that a center seam isn't always pleasing to the eye. If it has a pattern, try and match it, if you can.
