laminate floor
Old 08-06-02, 09:49 PM
mikyel847
Angry laminate floor
Hello there,
i got part of laminate floor damadge by water....
i really need someone to suggest me how to remove and replacethe damdge part of floor , considering that are glued togheter. Thank You so much.
Old 08-07-02, 05:33 PM
AzFred
Before you start, please confirm that you have or can get the exact color match and brand of flooring that is installed. Bring the replacement into the room where it will be used an let it acclimate for a couple of days. You will need a power saw, a router and a special router bit to cut a new plank groove or tongue. A local reliable flooring retailer will be able to help you assemble the needed repair items and advise you on the removal of the damaged planks. If you need more detail, come back here for help, if you wish.
