Sanding between Poly applications
How important is it to sand between applications of polyurethane. Between having to rent the correct floor sander, and the drying time between each coat, that could add a decent amount of money, and more importantly time before I can get my floors done. Last coat of stain was just finished within the hour.
-david
-david
Finishing a wood floor
Read and follow finish manufacturer's instructions carefully. Typically, an abrasive nylon screen or fiber buffing pad (white or brown) is used on water based finishes.
Some manufacturers recommend buffing the rough raised grain after the first coat. Some recommend application of a second coat in 3-5 hours without buffing. Follow buffing directions and use fiber pads or screens. A third coat is generally recommended. Application of more than two coats in one day is generally not advised.
How To Refinish a Wood Floor & Procedures for Finishing. FinishingWoodFloors.com. NOFMA. Retrieved 21 September 2002. http://www.finishingwoodfloors.com/f...es/manual.html
Learn more about finishing wood floors at www.finishingwoodfloors.com
Twelvepole's reply related to waterbase polys.
Oil poly needs at least a day to dry and does need lightlty sanding between coats. This gives something for the next coat to bite(adhere)to.
Let the stain dry at least 24 hours also/
fred
fred
Minwax - New Product
Minwax has a new oil based superfast drying polyurethane made specifically for floors. No sanding is required between coats and you can easily do 3 coats in one day. For more info go to www.minwax.com.
Hokiecoyote,
I use Minwax products almost exclusively (except for Thompsons deck sealer), and I'll have to see/try it before I believe it.
So far, I've never seen an oilbase poly product that doesn't need a day to dry.
I'll check it out,
fred
I'll check it out,
fred
