install methods
install methods
I am looking at installing mannington 3" gold series. Is this a fairly easy product for a diy'r?
Also, do you recommend floating or glue down? I have a concrete subfloor with no known moisture problems?
Thanks
Thanks
Installation of Mannington Gold Series
Each manufacturer tends to have very specific installation instructions to maintain product warranties. Read and follow carefully. You can learn more about Mannington Gold Series at www.mannington.com.
a floating install is widely considered the most diy'er friendly method.... the hardest part for me was cutting around corners, through closet doorways, etc... and making the transition to an adjoining floor can be a bit tricky, so plan that well...
you might want to consider flooring that comes in larger planks? laying down 4 ft. x 7.5 in planks means less fitting, glueing, etc...
hth!
hth!
