Baseboard Angles
Hi,
While installing basebord I have run into a problem with 45 degree inside corners and will appreciate any tips and pointers to help me overcome the challenge. The problem is that when I cut the two pieces of baseboard at 22 1/2 degrees they do not fit as the wall in the corner is kind of rounded (curved). Only way I can bring the two edges together is by having the baseboard seperated from the wall. For the baseboard to be flush with the wall, the 22 1/2 degree edges have to be seperated.
I hope someone here can understand my ramblings and help.
Thanks,
Moe
Thanks,
Moe
Cut your pieces to fit the anglr of the walls, they may not be a perfect 90°. Then trim the back side of the molding full height with a 45° across the "point". Plan on a fill, common even in new construction, with putty or caulk. If you will paint any acrylic caulk works just great. If you have a natural wood molding get a matching siliconized acrylic caulk that is color matched to your trim. Color-Rite and M. L. Kample are 2 brands that are available
