basement replaca floor
i want to replace my basement i did have a humidity problem but i think i fix it(all the triplex driher exit was passing true the basement to llong and cut every where.
BUT many people give ow to start some with plastic,some with ciment coating ,some with roof paper .but after a few wear i'm
affraid (some told about a plastic 2"by 4")so you,do you a solution
THANKS
THANKS
Basement floor options
Solid hardwood flooring should not be used below grade on concrete floor. There are engineered wood laminate and plastic laminate products available. Each manufacturer tends to make good, better, best levels of quality and warranties. Each manufacturer also has very specific instructions for the subfloor and preparation requirements and installation. Once you determine which product you will be using, then you will know where to begin.
