FELT PAPER, or RESIN PAPER???
Under hardwood floors; is there a functional difference between using felt paper, or using resin paper? If so, what is the difference? Which is better?
#15 felt has been is the preferred choice from the guys that put together the specs from The National Wood Flooring Association. Rosin paper actually originated as a method to reduce plaster dust from spewing all over when hardwood floors were installed.
Ken Fisher
floridawoodfloors.net
Ken Fisher
Installing wood floors
Go to www.installingwoodfloors.com for the National Oak Flooring Manufacturers' Association (NOFMA) instructions for installing wood floors.
