wood floor coming unglued
Gentlemen, Had a Robbins wood floor installed about two years ago over a floated concrete slab. I now have 3 places where it is becomeing unglued. It is naturally out of installation warranty so it is up to me to find a solution. Can this be fixed without having to replace 800 sq. feet of floor? If so is it something I can tackle without screwing up the appearance. All areas are in traffic/visible areas.
Thanks for the advice.
Lonestar
Lonestar
Glue down failure
If you followed manufacturer's instructions regard job site conditions, subsurface prep, acclimation and installation instructions including manufacturer's recommended adhesive, then warranty should cover you if you reported the problem within the warranty period.
Warranties are easily voided if installation procedures are not followed.
Job site conditions, failure to acclimate, adhesive failure, and moisture conditions tend to be common problems with glue down installations.
Find more info re: Robbins and warranty at http://www.ifloor.com/hw/1207/1207.warrant.shtml
Lonestar:
Is this a floating wood floor or one that is glued direct to the concrete slab? I have some possible solutions for you. Drop me a line and I'll send you some hyperlinks. If it's beyond a DIY job I have an excellant source in the Houston area you can contact.
ken@floridawoodfloors.net
Guys, sorry for the delay. The floor was installed by a flooring company which was under warrenty for one year. The concrete floor (slab) was floated to level and the floor installed with glue. Unfortunetely, glue is not holding in the three spots. I hate to take-up 800 sq. ft. of floor and would really hate to pay for it again. I was hoping there is some fix for the places coming up.
Lonestar
Lonestar
Lonestar:
Try this link for engineered floor repairs..Photos and everything for ya
http://www.hardwoodinstaller.com/har...er/repairs.htm
Lonestar:
You can't find a more clear description of the repair process anywhere on the internet if you checked the site. Have you copied and pasted the url?? If not, just go to www.hardwoodinstaller.com and locate the Hardwood Floor Repairs page link on the left hand side of the home page. The example is an engineered product glued to concrete as yours.
Hardwood Guy, I just left the site and it has great information. Thanks. I'm getting ahold of the main office of the Carpet Mills operation here in Houston and try for a solution. This is actually the second install of this floor. The first did the same thing only much quicker. When they ripped it up it took less than hour to do the entire 800 ft. Said glue was old and not enough of it. Appears the second install was better but not great either. Loose areas are not the same areas as first floor, so I doubt it is a problem on my end. Robbins guy didn't think so either.
Thanks for the help and I may check with the local guy you know.
Lonestar
Lonestar
