Seal the underside of flooring?
Old 11-27-02, 09:36 AM
Eric Pommerenck
Question Seal the underside of flooring?
I've been restoring floors, fireplace mantles etc. professionally for about 30 years. I would like to hear more pros and cons on sealing the underside of NEW flooring before installation.
Old 11-27-02, 07:08 PM
SteveOfloors
Check out the website at www.Floormasters.com. They just were discussing sealing the under side of maple and white birch, sand and finish floors. Are you considering this as a alternative to using a vapor barrier under the wood, or over the crawl space of the home. Seems awfully labor intensive to me. I would rather cover the crawl space, in most cases, but I live in an area where you can usually walk under the joists.
Old 11-27-02, 09:01 PM
Eric Pommerenck
Thankyou, I'll check out the site. The sealing would actually be in addition to a vapor barrier, The winters here can be fairly cruel. Thanks again!
