Laminate floor transition at a threshold
We are installing a laminate floor in the basement. There are 2 areas where we have questions. We can't find a molding that seems to be appropriate to use at the threshold of the outside door. Also, we have a fireplace hearth that has curved corners that we have to lay flooring around.
Question # 1) Should we just stop the flooring 5/8 inch from the threshold without covering it with any kind of molding?
Question # 2) Should we do the same thing at the fireplace hearth? Or is there a molding that will curve around corners?
Thanks so much for your help.
Transitions
You should be able to find a threshold for the outside door at a local home improvement store as far as the curved fire place what you can do is use a colored caulk around it. simple and effective and also allows for the proper gap for expansion and contraction
Philly
Philly
Is the door in right now i would assume it is some doors have a removable threshold in the center the screws are generally covered you could remove it and replace it when you have laid the floor.
if not a simple reducer from the door to the floor should take care of it . you just don't want to end up with a toe catcher if you know what i mean
Philly
Philly
Either remove and then replace the threshold, undercut the entire threshold for the door and the doorjambs at the same time, or use an "end cap" molding, also called a square stair nosing.
If your fireplace is a raised hearth, Undercut the stone using a plank of the laminate as a guide and use an angle grinder with a small 4" diamond blade. Caulking at a fireplace hearth looks tacky to me, not to mention the cut edge chipping the sometimes occurs with any laminate.
It would be helpful to know if the hearth is smooth or rough. Brick, marble etc. Vs. field stone slate or flag stone. Perry, I think the square edge is not really a stair molding. ??? The edge molding can also be used around a hearth if the surface is not too irregular.
I wish we could still post pictures here!
iFloor.com has some molding profiles to look at.
They call the same shape molding an end cap in one picture and on another manufacturer, the same profile is called a square nosing. I have rip cut a "T" molding to make it into an end cap too.
