Help/Hardwood refinish!!
Old 01-02-03, 06:01 PM
williaml
this is going to sound nuts.Does anybody know of a seler that can be applied over linseed oil?Will polyuerathane work?thanks in advance
Old 01-03-03, 06:57 AM
David Leonard
From everything I have been reading you will need to: screen or light sand the floor, clean well with mineral spirits to remove all wax and contaminants (it might be a good idea to clean with mineral spirits first). The screening may not be necessary either depending on the condition of the floor. Then you can apply the poly. The poly would likely not adhere to the floor without a sealer, bond coat.
Below is a link for one such sealer product.
http://www.zinsser.com/product_detail.asp?ProductID=72
Here is a link for a poly recommendation:
[This is a follow-up to your posting on
That Home Site!'s Flooring Forum, located at:
http://ths.gardenweb.com/forums/flooring/ ]
_______________________________
