laminates
Old 01-16-03, 07:16 AM
charles higgins
Unhappy laminates
When installing laminate flooring that has to be tapped together
with a mallet how do you hit it when you get to the opposite side of the room ,when trying to install the last piece the wall is in the way
Old 01-16-03, 07:41 AM
Texas wood
They make a pull bar. It goes over the edge and you hit it with a hammer. Make sure you protect your floor underneath the pull bar when you hit it. Home Depot sells them. It will be obvious when you see it.
Old 01-17-03, 08:54 PM
I call that my slapper. I rarely use it though.
Looks like a Z. or really an L with a top on it. Besure to step on it as you hit it with the hammer.
One of those flat prybar/nail bars. I use it to pry with sideways in the expansion. Then slap the plank with the palm of my hand a couple of times and "click".
