GLue down, Nail, Staple, FLoat HELP
Ok, I am going to install a engineered hardwood floor. Probably a mirage or mannington. Depending on which one I choose I have those 4 installation options. THis will be on a 1st floor with a standard plywood subfloor. What are the pro's cons of each method.
I don't think there are many engineered wood floors out there that can be installed with the traditional nailing process. Most engineered floors are either glued or floated.
- Glue: solid and "quiet" floor, slower install, 1-2 day dry time
- Float: "noisy" floor, quick install, ready to use same day
Personally I prefer a glued engineer floor but I recommend you walk on some in the store to get a better feel for the final product.
Good luck.
Good luck.
