hardwood flooring up to a bathroom marble threshold
Old 03-28-03, 03:41 AM
Chessy1
In the process of hardwood flooring up a hallway to a bathroom entrance that has a marble threshold. Are there any do's and don'ts that I should be aware of or do I floor right up against it and make a tight a fit as possible. Also should I caulk or anything like that between the two?
Mark Efird
Charlotte, n.c.
Old 03-28-03, 03:47 AM
Locy's Hardwood
What we like to do is leave the same gap as the grout line and caulk the gap with caulk that matches the grout unless there is a height differnce then a transition piece is in order.
philly
