Laminate flooring
Old 03-29-03, 08:37 PM
Davy68
Laminate flooring
My daughter had a fire and wants to replace her floor. It is glued down to concrete. It is taking forever to get old floor up. Rented a tool that looks like a flattened hoe that is attached to a vibrating shaft (?) (air compresser). Any ideas on how to speed this up. 3000 sg ft. Worked two good days and got the LR finished.
Old 03-29-03, 09:30 PM
Cedwin
If it is laminate it should not be glued down.
I assume you have a glue down wood. I know of no easy way to take this up. Keep the hoe sharp.
It takes a lot of blood sweat and tears.
