Cutting out a section of subfloor
Old 05-27-03, 04:06 AM
Chessy1
I have about an 8 foot by 8 inch section of subfloor that runs along a wall in my hall that has a crown in it that needs to be somewhat leveled out so my hardwood will lay flat. Question is if sanding don't take it down enough and I have to cut out the bad section will this weakend my floor. Also what grain of sandpaper would you recommend to take this crown down to size.
Chessy1
Old 05-27-03, 07:09 PM
C
60 grit should do it.
Any subfloor removed would have to be supported when reinstalled. It would be better to cut along the floor joist so that a replacment piece can be installed on and fastened to the floor joist.
Hope this helps.
