Laminate Flooring
Old 06-01-03, 09:30 AM
rickflor
Unhappy Laminate Flooring
What did i do wrong?
I installed Laminate flooring about 6months ago and now when walking on it, it's starting to make a cracking sound.
can this be fixed?
thanks.
rickflor@earthlink.com
Old 06-02-03, 07:08 PM
Your not keeping constant temperatures and humidity levels inside the home, or the expansion gaps left around the perimeter, have locked in somewhere. It is hotter outside, and more moisture in the air. Wood expands with heat & moisture.
