Lamiante over Concrete
Old 06-11-03, 02:46 PM
T
Hi all, I just purchased approx 540 sq ft of the QuickStep Perspective. I am laying this down over a 3 yr old concrete floor.
Should I patch the small holes that are left after removing the rug tackless strips...
Any info would be appreciated
Thanks
Anthony
Old 06-11-03, 05:11 PM
I patch them if they are huge, across a transition or area walked on, and of coarse the homeowner I have bid high, because I could tell they were going to be extra picky, and no use explaining, when I charged them for this service in my bid.
What I would do now is stretch a string across the floor in all directions, to determine if the subfloor meets the 3/8 inch in 10 feet rule. If the floor has low spots greater then this, floor preparation is in need. Don't skip this, or you'll be sorry you did later.
Old 06-11-03, 06:56 PM
T
Carpets Done Wright
What type of material should I use to patch the small holes.. and what do you mean by the 3/8" by 10"to see if it's level
Old 06-12-03, 04:14 PM
Patch with a polymer fortified cement, like Ardex SD-F(Ardex.com)
OOPS! That should have read 3/16" in 10 feet or 1/8" in 6 feet.
That is how flat that subfloor needs to be to meet the manufacturers and industry standards for subfloor flatness. If it isn't, the product warranty is void. Read all the installation specifications fully and understand ALL of the instructions before starting!!!!!
Are you planning to undercut the doorjambs, if there are any to be undercut?
Old 06-19-03, 09:31 PM
T
How long does the flooring have to sit in the environment before it is put down....
Old 06-20-03, 03:40 AM
The installation specifications that are in ech carton of flooring, should outline and define acclimation.
Usually 48 full hours. Me personally, I let it sit for a week.
