Installation over carpet
Old 06-26-03, 09:07 AM
Bijou
We've recently purchased a house and have decided to remove all the carpeting and replace with laminated floors throughout. Part of the house was carpeted with a very low pile. Is it advisable to lay the laminate flooring over that or should we remove the carpet and proceed with the underlay?
Old 06-28-03, 09:37 AM
floorman
remove that old carpet and use the padding that is reccomended by the manufacturer
Old 06-30-03, 09:24 AM
Bijou
Thank you so very much for the reply
I had hoped to avoid some grueling work as the carpet is glued down VERY WELL! hehehe
Bijou
Old 06-30-03, 09:46 PM
Oh ya, you have some work ahead of you.
Renting a mechanical gluedown carpet removal machine, might save you some blisters.
You are still going to have to scrape the floor, to remove the adhesive residue, or use a chemical, since your not gluing something else down.
Old 07-01-03, 12:10 PM
Bijou
YUCK!
