Laminate floor
Laminate floor
I installed impact laminate tiles about 9 months ago, I used a D-3 laminate floor glue, I wiped the glue up as I was going. A week after floor was installed I noticed that there was a haze on my floor from the glue. I tried several glue removers of which none of them worked. I also tried alcohol, acetone and citrus cleaner to remove this glue and none of them worked.
What can I do to remove the glue from my floor without damageing the laminate, have I waited to long and my floor is ruined.
If you used D-3, I suspect that you may be in Europe. D-3 is classified PVA-II in the USA. If the Armstrong glue remover (maybe not in Europe) is still available, give it a try. Your problem comes from a glue saturated or poorly cleaned clean up rag during installation. For those who haven't yet started, keep the clean up rag super clean, use it often, clean it often and rinse twice.
