install ceramic tile over parquet
I had a professional ceramic tile installer tell me that I could put down cement backer board (1/2") directly over 6" parquet squares. In the rooms where carpet is down, just put down 3/4" backer board to compensate for the height of the parquet. The sub-floor is 3/4' plywood, on 16" centered joists. This would preclude the need to take up the parquet in order to lay the ceramic.Would the heights(carpet to parquet) match? Will there be excessive deflection/movement? Is this good advice? It sounds to good to be true. Any advice would be appreciated.
