Laminate and Paruet Flooring
Old 11-07-03, 08:18 PM
rlrcstrs
I was considering putting laminate floors throughout my home (1500 sq ft) but with installation it works out costing a small fortune.
In contrast, I looked at parquet floor tiles. Those are nice. It seems you can put those down just as you would lay down self-stick linoleum tiles. Is that true?
Also, how does the cost compare with laminate flooring?
Old 11-08-03, 06:39 AM
From my years of experience, self stick, or mostly called peel & stick flooring is a waste of hard earned money.
The glue on the back is not like the glue on the back they had 30 years ago. It is cheap junk.
Old 11-08-03, 07:08 PM
AzFred
Every now and then I have to rise up and point out that cheap solutions to decorating can devalue a home.
Go cheap and damage your larger investment. The bigger picture to the wisdom in Perry's remarks.
Old 11-10-03, 09:55 AM
florcraft
I concur a million times over. Wait till you have the money to keep your investment wise.
