How to cut existing subfloor flush with walls?
Old 01-30-04, 04:40 PM
L
I have an uneven subfloor, and it has crowns. It was suggested by user Lefty that I completely remove the subfloor and install 3/4" plywood as the new subfloor. I'm liking that idea, however I'm concerned about how I might pull it off.
What tools & techniques can I use to cut the subfloor flush with the existing wall? I have a circular saw and a reciprocating saw but I'm not sure I can get them to make a flush cut.
Old 02-01-04, 08:27 AM
johng chevy
You can use a towkick saw which will leave a 1/4"left and at the corners you chisel out.If you can't get the saw try the sawzaw but it tends to bend the blade.
Old 02-02-04, 09:11 AM
L
Thanks, I haven't heard of a towkick saw before. I'll check it out.
Old 02-03-04, 05:00 AM
Go here, and click on specialty saws, then scroll down to toe kick saw. The first saw pictured is an undercut saw.
http://www.craintools.com/
http://www.craintools.com/new_products/795_complete.gif
Old 02-03-04, 12:42 PM
L
that is one cool saw!
