Underlaying on cement floors
Old 03-02-04, 08:10 AM
lo21133
I live on the bottom floor of a building and I want to put it hardwood floors (strips). Do I need underlaying? My floor beneath the carpet is concrete, as of right now it is hard to tell if it is copmpletely flat. Would you recomend I fill in the cracks and repair some of the concrete (if any is needed and then lay the hardwood on top of that? Should I use plywood?
someone help!!
LM
Old 03-02-04, 10:28 AM
florcraft
fill in the cracks and make the floor flat with a leveler, then lay a moisture barrier, then an engineered floating wood floor.
your done
Old 03-02-04, 11:37 AM
lo21133
What do you recomend as a leveler, and also what do you mean a moisture barrier. I am sorry I am just beginng to research this and am not always up on the terminology.
Thanks for your help!
Old 03-02-04, 11:47 AM
florcraft
I use webcrete, but other installers might have a better leveler.
a moisture barrier is at least a six mil poly that you lay down first, including up the wall a bit. Then you lay the floating wood.
a moisture test at home depot might be a good thing to buy first as well.
