More help needed installing laminate floor
How do you deal with installing laminate in a room where one side of the room has baseboard heat?You can't use the spacers on that side.Do you have to remove the baseboard? The flooring we would like to install is Pergo Prodigy ( no gluing).
Laminate floor and baseboard heat
If baseboard heaters do not consume the entire wall, then use speacers as recommended on wall where baseboard heaters are located but not beneath heaters if it is not possible to use spacers beneath heathers. Expansion gap will be covered by heaters. Areas where heaters are not located, expansion gap can be covered with recommended trim pieces.
