floor framing
floor framing
I'm preparing to install new prefinished Kempas 3 1/2" floor in my sunroom addition of our 1875 "workmans cottage". I understand flooring should be laid 90 to joists, but what if the framing changes where the room takes a turn & half the floor runs with the joists. The subfloor is 3/4 sound plywood. What kind of problems should I anticipate & is there anything I might do to not have it happen.
Wood floor changes directions
Wood flooring is installed perpendicular to floor joists. If joists change direction you can change the installation direction, too. Rip a spline from a piece of flooring or other wood and sand to the correct dimensions so that you can slip it inside the groove. This is sometimes called a 'slip tongue.' It allows you to slip the grooves of adjoining boards that are taking off in the new direction.
