engineered floor over concrete subfloor, glue-down or floating?
Old 10-18-04, 12:11 PM
Question engineered floor over concrete subfloor, glue-down or floating?
Hello,
I just bought a 50 year old house that is on a concrete slab. I would like to install a hardwood foor, I would like to see what you recommend. Installing over concrete, I know I need an engineered floor. What is the best way to install it, glue-down or floating floor?
With a floating floor, I can place a vapor barrier and pad between the concrete and engineered floor. I assume this will make it a little softer to walk on. The glue-down method would have the wood directly attached to the concrete, therefore much harder to walk on. I assume installation of the floating floor is much easier.
Thanks,
Mark
Old 10-18-04, 06:51 PM
florcraft
Float it 100%
