Hump in my floor
Old 01-19-05, 10:34 AM
TheHammer
Hump in my floor
I am going to be installing a laminate floor in my dinning/living room area. (probably Dupont) There is a bit of a hump in the floor down the middle of the room, its flat for about 10' and then humps down about 3/4" over the next 8'. I was going to put the floor in longways over the hump.
Is this going to be a major problem in the future? The box I have for a sample lays over it just fine and is not raised.
Old 01-19-05, 03:35 PM
Failure to adhere to the strict substrate flatness specifications, for laminate flooring is a recipe for failure.
Read the substrate flatness specs for the laminate you choose. Then don't install the flooring until the substrate meets those specs.
Old 01-20-05, 04:32 AM
bvanscoy678
hump
Your floor will be doomed for failure! Plus, warrenty will be worthless.
Old 01-20-05, 05:35 AM
TheHammer
Thanks for the help , I'll just have to rip the ply up and level it off better, that part on a slope used to be the porch and it settled differntly over time..... might even be able to re-hang the joists. Guess I won't know till I open it up.
