Refinishing wood floor
My house has three upstairs bedrooms with hardwood floors. They are the narrow strips, put in almost 100 years ago. I would REALLY like to refinish them myself and wonder what the best process is. Or would you recommend getting them done professionally.
Thank you,
forestgrn
Thank you,
forestgrn
If the scratches and wearing is not deep, you may be able to just put another layer of finish. Do a very light sanding or use a screen, and apply finish. Here your are only sanding or screening enough to provide adhesion for the new coat of finish. You could rent a floor buffer with a 120 screen. (However, if the floor has previously been waxed you may have problems)
If it's deeper, or if you want to alter stain color, then a full sanding is required. 3 passes of sanding at increasing finer grit- 40/80/100. then stain and seal plus 2 coats of finish.
You can rent a floor sander for this. This can be done DIY, but I will warn you that getting an even sanding takes some experience. Most DIY's will find sanding "bounce" marks and start/stop marks. A bedroom is not a bad place to learn tho, as it's usually covered by more furniture, and of course, not public.
Go to www.nofma.org for the National Oak Flooring Manufacturers Association's technical manual on finishing wood floors for instructions.
