Oak Lumber flooring Calculation
Old 07-13-05, 02:20 AM
R
Question Oak Lumber flooring Calculation
I am wanting to cover a 120 sqft room. I need to figure out 2 3/4 wide and 1 linear inch would it take to cover the room?
Could you please show the calculation?
John
Old 07-13-05, 05:13 PM
120 x 12 = 1440 sq. inches
1440 / 2.75 = 523.636 linear inches
Old 07-13-05, 05:22 PM
D
add ten percent to the final number and that will be the ammount to order. waste and undesirable boards, trust me there will be a few.
Old 07-15-05, 12:11 AM
sunlaker
Revised Calculations
I think you might take another look at your calculations. I came up with something different.
1 sq ft = 12 in x 12 in = 144 sq in
So 120 sq ft = 120 x 144 sq in per sq ft = 17,280 sq inches
17,280 sq in / 2.75 in width = 6,284 in length. So you need
6,284 in / 12 in per foot = 524 feet of flooring that is 2 3/4 wide to fill a 120sq ft room.
Adding the 10% margin, you get
1.1 x 524 ft = 576 feet of flooring required for the job.
I think this correct. To give it a sanity check, if your room was 12 ft wide by 10 ft long (120 sq ft), you would need 12 ft x 12 in per ft/2.75 in wide = 144/2.75 = 52.4 strips laid side by side to span the width of the room. Since each one of those strips has to be 10 feet long, you need a total length of 52.4 x 10 = 524 feet of flooring. Add 10% margin and you need 1.1 x 524 = 576 feet required. Same answer as before.
I hope this helps. I was just passing by, trying to get smarter on wood flooring, and I saw the post on calculating footage for a 120 sq ft room. I thought I would throw in my 2 cents worth.
John
Sun Lakes, AZ
Old 07-15-05, 07:04 PM
John
Sun Lakes, AZ
OK, I'll round up
523.636 board inches Rounded up, 524 board inches
Old 03-29-06, 02:15 PM
R
thank you
Thank you , for your help.
Old 03-29-06, 02:34 PM
B
Originally Posted by Carpets Done Wright
OK, I'll round up
LOL and to think you were about to give that poor guy .4" improper quote!
Old 03-29-06, 08:36 PM
R
Red face Lets take this one step further
If the boards come in 5' lengths X 6" and are .20 a lineal inch how much would it cost? John
Old 03-30-06, 06:05 AM
What ever the market will bare!
Your asking a trick question, when there is so much out there to chose from.
Old 01-04-13, 09:42 PM
R
So If each box of tongue and groove flooring covered 17.8 square feet of space and the room was 19' x 12' then you would :
(1) multiply 19'x12' =228 square feet +22 waste and cast offs then
(2) divide 250'/17.8'= 14. Am I right? How many 4'x8' sheets of playwood do I need to cover the area?
I come up with 8 roughly. Did I do that right?
John
Old 01-05-13, 05:09 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
After 8 years, and you haven't got this project done, yet?? Yes 14 boxes of flooring at your current specifications. Plywood comes in 4x8 sheets, or 32 square feet. Divide your room total by 32. You will need 8 sheets of plywood.
