Laminate Floors Installation
undefined
Hi, I couldn't find the answer in the many threads listed. Probably just got lost in the abundance. Question: Is it OK or advisable to install over vinyl tile that is in good condition? Also, how do I transition to the concrete slab in an area that was carpeted? Thank you so much..
Tiles are not the same as a solid sheet vinyl. Some manufacturers say OK, some say not to go over concrete with vinyl tile, because it may cause the tiles to lift.
Check with your laminate manufacturer, not the guy that sold it to you.
