Laminated Flooring in Winter
Old 09-26-05, 09:13 AM
4agreatdeal
Smile Laminated Flooring in Winter
Hi all: Just purchased a cottage in Gatineau, Quebec, Canada. The cottage has laminated flooring throughout. The building is on blocks, with a plywood skirt around it. The winters can get down to about -40F. The floor has vapor retardant foamlike material. There is no other insulation beneath the floor.
Now the question is, do I need to keep any heat in the cottage during the winter. If yes what is the lowest temperature that it should be set at
Thank you
Bernie
Old 09-27-05, 09:53 AM
Do you still have the specification paperwork the came with your flooring?
Read the part about maintaining constant temperature and humidity levels year around, or expect problems.
Old 09-29-05, 08:30 PM
T
Received 2 Upvotes on 2 Posts
Floor covering products tend to perform best if temperature and humidity are maintained year round at constant levels. Temperature and humidity should be at occupancy levels for best performance.
