Install hardwood floor in stairs
We want to install hardwood floors upstairs. However, my husband is concerned how to do the stairs. Are they any videos available as to how to do stairs? Is it difficult. What do you use at the end of each step?
At the end of each step, you use a piece called a bull nose. It is half rounded on one side, or on one end depending upon your staircase. Most hardwood floor companies will have some to match your flooring. If you bought your flooring at a Home Supply or discount store good luck.
Jack the Contractor
Jack the Contractor
