wood flooring over concrete
Old 04-13-00, 12:33 PM
Guest
Question
I am interested in putting a prefinished wood plank floor in my kitchen and hallway but the floors of this building are concrete. Can forgo a wood subfloor and use an adhesive for the project?
JeffreyB
Old 04-14-00, 12:49 PM
Guest
Cool
If it was my house, I'd put in a sub-floor first. You might also want to consider using thin foam backing similar to the backing designed for laminate floors. This will soften the floor and provide sone insulation keeping the floor a little warmer.
Ted
Old 04-15-00, 09:32 PM
Guest
Post
Here's some good stuff to check on: http://ardex.com/link-comm.htm#flooring&wood
and yet another product that may work for you: http://rapidfloor.com/lrpl.htm
MTAC - Van Buren,MO
www.carpenter.cjb.net
Home repair & Construction
"Where the character and work are always upright"
Anything worth cutting down a tree for, is worth doing right.
www.toolreview.cjb.net
[This message has been edited by More than a Carpenter (edited April 16, 2000).]
