Remove Epoxy\install glue on new woodfloor
Old 10-01-05, 05:04 PM
CoreynStacy
Question Remove Epoxy\install glue on new woodfloor
Hello,
I just had 630 sq ft of Oak hard wood flooring. Being on a slab foundation and in N Texas it has to be glued down. The installer used a epoxy based wood flooring glue and managed to get a lot of slopy spots on the surface of the new hard wood floor.
Question: Can anyone help me find a way to remove the glue without removing the finish? TY xxxxxxxxxxxxxxxx
Last edited by twelvepole; 10-02-05 at 02:24 PM. Reason: Email addresses and contact information not allowed in forums
Old 10-01-05, 08:35 PM
T
Received 2 Upvotes on 2 Posts
Won't the installer correct his mistakes? He should have left you with a "ready to use" floor in perfect condition. That's what you paid him for.... I'd call him back out....
Especially since I don't have a clue how to get epoxy off the floor without possibly screwing it up....
good luck and I hope someone can give you the DIY answer....
Old 10-02-05, 10:09 AM
D
Call the dealer from whom you purchased the floor, it is their problem not yours.
Old 10-02-05, 02:25 PM
T
If wood has a polyurethane finish, acetone can be used to remove epoxy glue without damage to finish.
Old 03-29-06, 06:12 PM
I need help
How would you remove epoxy tile glue from a cement basement floor?
Old 03-30-06, 06:14 AM
Ya, since the installer did it, and made your investment look bad, ask the store the installer subcontracts from, to make you whole, again, giving you what you were paying for.
