Laminate hardwood in the kitchen
Old 10-04-05, 03:25 AM
I'm going to install a new floor in my kitchen. There is existing linoleum flooring that I plan on installing over, rather than the hassale of removing. Any problem here? Also, the biggest challenge. The floor is badly out of level at a door entrance. Can I pour some type of liquid foundation to get it true?
thanks!
Old 10-04-05, 09:29 AM
If this is a floating floor, yes you can prep the surface for flatness over the sheet vinyl, unless the substrate under the vinyl has too much deflection movement.
