Saddles
Question,
I installed a new parquet floor in the kitchen and it is now a little higher that the floor in the dining room and hall. Is there a special saddle I need to address this difference in "elevation"? If so, any ideas where i might find one?
Thanks,
hanemen
Thanks,
hanemen
What's the difference between the two? Most parquets are 5/16" in thickness. If you're up against 3/4" hardwood I would suggest a "baby threshold," but it would likely be a real stoe stubber. There are other options such as remilling a baby threshold with the use of a table saw to make the transition more gradual. In this case cutting the bottom of the threshold on a 20º +- may do the trick.
Ken,
Thanks, for the reply. The new floor height is a standard Bruce floors parquet tile high plus a little more due to the sub floor. I'm afraid a standard saddle will "rock", or break off some of the floor edges. Is there something called a T saddle, which will compensate for the difference?
You'd need some type of overlapping transition piece and the best one I can think of to mind considering your situation is made by Harris-Tarkett. It's about 2" wide and is designed to make a smoother transition from vinyl or ceramic tile to their line of 9/16" hardwood. Last I looked harris-tarkett.com was down or they were updating so I can't provide a good pic.
Try this... floorboards.com, click on Harris-Tarkett Longstrip, then transition pieces at the bottom. You'll see a profile of the overlap reducer....hit the help me button...pictures are worth a thousand words!
Good Luck
Good Luck
