cork underlayment with floating floor
Old 10-21-05, 08:54 PM
smunn
Can you tell me how cork underlayment is applied when floating an engineered floor on a concrete slab with vinyl tile?
Old 10-22-05, 03:18 AM
Sometimes it is glued down, and sometimes it can be loose laid.
Old 10-22-05, 01:36 PM
smunn
Is a vapor barrier necessary?Above or below cork? What thickness cork,3mm or 6mm?
Old 10-22-05, 07:41 PM
A moisture barrier, be it sheet, or coating form, should always be used over concrete. Depends if you wish to gluedown the cork or float it too, as to which one to use.
