oil or water polyuerthane for hardwood floor
Old 11-17-00, 06:08 PM
Guest
Post
We are refinishing light hardwood floors with a darker color: sanding, staining and finish coat. Any thoughts on the advantages of wax, oil based poly or water based poly? Thanks very much
Old 11-17-00, 08:45 PM
Guest
Post
If you can stand the fumes, oil-based poly is the most durable. Water-base poly is often used by residents or installers with chemical sensitivity. If you use water-based, you can make up for it by putting on one more coat than you would have used with oil-based.
