Transitions between rooms
Old 11-02-05, 12:00 PM
hellomoto
I am planning on nstalling laminate flooring in the entire house (minus bathrooms). Are transitions needed between rooms and hallways even if I am installing laminate in the entire house?
Old 11-02-05, 04:04 PM
D
I would think most likely...depending on which and what laminate floor you are buying and what they require as per instructions. Find out your total sqft first for each room and total every room too and then go from there. But other people may have better suggestions than me. I am putting transition pieces at each bdrm door just so there's an expansion gap there. Don't want to short cut anything!
Old 11-02-05, 06:54 PM
What does the laminate manufacturer require?
They are all different, and all have their different views of that situation.
With a glueless system It is a good thing to use expansion and movement transitions between rooms.
