glue down vs floating
Old 11-14-05, 02:39 PM
sambadancer
HI
I am planning to install engineer wood floor (mannington, Jamestown) in my new condo. My unit is in the second floor. I believe my subfloor is light weight concrete. I wonder if I should use glue down or floating technique. Any pros and cons? I am also thinking to install it in the kitchen area. I am not sure if that is good idea. Any recommendations on that?
Old 11-14-05, 05:34 PM
D
Float it, gluing to gypcrete is a recipe for failure.
Old 11-14-05, 07:19 PM
I hope your in tight with your down stairs neighbors!
What does your condo association say about hard surface flooring on the upper levels?
Old 11-14-05, 07:46 PM
gorth97's Avatar
Make sure your HOA allows wood/tile floors on the upper units. My association and my friend's association has it against CC&Rs/byLaws. I was reviewing old HOA newsletter and they made some people remove their hardwood flooring and install carpet throughout.
Old 11-15-05, 08:56 PM
sambadancer
thanks for your suggestions. I never think about condo association rule before.
