Laminate to Carpet Problem
Old 11-16-05, 06:33 PM
ronmac
As I moved my way down the hall, I have come to a dilemma. The carpet and padding in the bedrooms that the laminate must go up against in the doorway is too tall for the 4-in-1 moulding with carpet transition. The height of the carpet and padding is about 1/2 inch over the top of the moulding. How can I transition and not make it look funny. If I butt the moulding up to the carpet as is,you can see some foam and the entire carpet cross section. Help!!! Thanks.
Old 11-17-05, 06:03 AM
An endcap molding, and carpet tackstrip.
Tuck the carpet neatly behing the endcap molding.
Old 11-17-05, 10:58 AM
ronmac
I will try that. It just seems like the carpet and padding are soo thick and will not meet the end cap close enough.
Old 11-20-05, 08:50 PM
D'Olier
Using the carpet tackstrip, also means the padding will be cut back about an inch and a half under the carpet. Your carpet won't be as high when it meets the laminate.
Old 11-21-05, 05:56 AM
Correct.
The padding is not over the tackstrip.
Tackstrip runs around the perimeter of the room where carpet is installed. Padding is then rolled out and trimmed up to the tackstrips.
