prep for floor
Old 01-13-06, 11:31 AM
D
Question prep for floor
I looking to put down a floating laminated wood floor on a slab. The slab is not level , it has high and low spots. The slab also has a glued down linoleum floor on it.
Can I use a leveling compound over the top of the linoeum flooring?
Thanks
dtrkjr
Old 01-13-06, 10:11 PM
R
If you have "true" linoleum, no, the oils in the product will repell floor compunds. If you have a cushioned product on an inlaid vinyl floor, yes you can use the product.
go to " http://www.mapei.it/referenze/Multim...nM20_TD_EA.pdf " ,that will list the procedures.
