Polyurethane Flaking on Pine Floor
I installed a pine plank (5 1/2") floor in a sunroom about a year ago. I used Minwax stain, two coats, and went by the directions. Then I put two coats of Minwax Polyurethane going exactly by the directions. Less than a year later, the Poly is flaking/yellowing and scratches very easly. You can even scratch the coating with your fingernail. This floor expands and contracts just like any pine floor should do, but I never expected the surface to look so bad in such a short time. I'm thinking of sanding it down, restaining and then use a wax coating. Any ideas would be great. Thanks.
in anycase the floor needs to be resanded to the bare wood and new stain and finish.
Thanks for the replies. The drying time for the stain was about a week. Can anyone tell me if a paste wax finish over a stained pine floor would work ?
i would not wax the floor it is just a pain to maintain, i would resand and try a waterbase finish from bona www.bonakemi.com the water base finishes today are much harder then the oil finishes but you cannot go to homedepot and buy a quality water finish anything they have sucks trust me i know.
