laying engineered hardwood over ceramic tile
We are currently in the middle of a kitchen remodel. We are considering engineered hardwood (not laminate) and was wondering if I could glue it down over the existing ceramic tile instead of floating it? In my experince, floating engineered hardwood gives it a hollow or emty sound and feel. The tile is in good shape and has no loose or uneven tiles. If this is possible, is there a special glue to use or just the standard. Thanks!
Yep, use a moisture cure urethane adhesive. You may need to emboss the grout lines, with a latex and portland cement patching compound, to fill them in. Also chipping high edges of the tiles that may not be sitting flat.
Thanks for the info. Now when you say "may" need to emboss the grout lines, does that suggest that if my grout lines are not very deep, that I don't need to emboss them, or do you suggest I do that anyway. FYI: the previous owners put in a commercial grade type tile and there is very little variation from the grout lines and the tile.... very ugly I might add also! Thanks again!
