CDW: SLC usage questions
Perry,
How do you handle pouring SLC into a corner where the corner is the lowest point? Do you tape between the dywall and underlayment to keep the SLC from running into the expansion gap?
What do you use to seal around pipes that run through the floor? Silicone caulk?
I live in the land of concrete. I have never used SLC over a wood structure.
I would make real sure there is absolutly no deflection in the substrate before you waste your time and money. If you have never worked with SLC before, your in for an education.
