Subfloor for laminate?
Old 02-24-06, 07:53 PM
belayme
Can I use OSB over plywood?
Thank you....
Old 02-25-06, 12:23 AM
Yes, that will work fine under a floating laminate.
Old 02-25-06, 09:03 AM
belayme
Great! Thanks!
Old 02-25-06, 11:24 AM
belayme
What would be the best way to secure it? Nails, glue or screws?
Old 02-25-06, 11:35 AM
You are supposed to screw down underlayments to subfloors, don't try to hit a joist on purpose, run it perpendicular and keep the seams all staggered with an 1/8" gap. I run beads of yellow wood glue on my jobs.
Old 02-25-06, 12:27 PM
belayme
Wonderful. I got screws on a whim and will go at it trying to not hit a joist. I did lay them down perpendicular and am including a gap.
Thank you for your feedback.
