Gaps and delamination in engineered wood floor
Old 03-09-06, 07:21 PM
L
Just had 450 sf of Bruce maple 5" engineered wood flooring installed by local contractor. The floor was glued to Phoenix concrete slab. Installer said moisture test was about 4 as I recall. How much gap is acceptable? Some people say "none", but that seems impossible. Upon close inspection there are quite a few gaps that are not even dime width, but about and some thicker than a small olfa utility blade. Should these gaps be addressed by the installer in any way? I was expecting this "High Quality" professionally installed flooring to come out as tight as the HD TrafficMaster laminate I installed myself in the kids bedrooms.
Also, it seems one board has delaminated along the long end - center. The floor is completely installed now. How should the contractor handle this?
Thanks, LJ
Old 03-09-06, 07:33 PM
Bruce and High quality should never be used in the same sentence, unless it is Studio B, from Bruce.
A gapped floor is pretty common with Bruce, who is the only manufacturer that I have seen, state in their installation specs, wood filler must be used.
A board replacement is needed to get the bad board out. What did he use to get "4" ans a concrete moisture reading? 3# per 1000 sq.ft is the limit, with a CC test.
Old 03-09-06, 07:55 PM
L
At over $5/sf and compared to the others on display... it seemed... well, what is a good engineered wood? And how much does THAT cost?
As far as the moisture, I may be mistaken about the number, he just mentioned it before installing the floor. He said it was dry. That was good enough for me - what do I know - that's why I hired a contractor. Could this be a factor so soon?
How do they replace the board without tearing back to it?
Old 03-09-06, 08:07 PM
Well, Studio B is around $9 to $12 a sq.ft depending who sells it to you.
Mirage is about $7-$9 a sq.ft depending who sells it to you.
The installer knows how to do a board replacement. No need to write a book about it here. Cut the board out and insert a new board after modification of the groove sides.
Old 03-09-06, 09:04 PM
L
Thanks. Should I have him do anything about the gaps, or is that just the nature of the product?
Old 03-11-06, 05:37 AM
Old 03-12-06, 10:10 AM
R
Unhappy
We've seen specs from Mannington on some of their engineered as well as the stuff that comes from China, stating that "some wood will need filler".
It's a bugger, they leave everything into the installer's pocket to fix their products. Then it's hard to convince the customer that this is a "normal" procedure!!".
