Quick step Laminate on top of Pine planks?
Old 07-08-06, 04:22 PM
I have pine planks, the looks of which I donít like. Can I install quickstep laminates (It is 8 mm in thickness) on top of it? Or should I remove the existing pine floor that is ĺ" thick and put plywood so that the finished height meets existing ĺ" thickness?
Also is it necessery to put a cork underlayment before installing the quick step 8 mm Elegance ?
Old 07-13-06, 12:12 PM
D
Received 2 Upvotes on 2 Posts
You should always go with what the manufacturer's instructions say. Here's Quick Steps installation instructions.
http://www.quickstep.com/installing-...ring.aspx?id=6
About planks are on page 2 #4 under "PLANK FLOOR"
I hope this helps
